79 Shovel, was running fine, then everyonce in a while it would pop out the carb. Then it went down hill from there. Now it will start and idle fine, but when you start it bogs and pops a bit. It has fresh points, plugs, and intake bands. Valves have been set, carb cleaned, all passages blown out. It has a Super E carb, pump seems to be working, crack the throttle and it squirts. Every once in a while it seems to clear up and run fine, then back to this.
Any ideas?
Any ideas?
