Shocks or just glorified struts?
7.9K views 9 replies 6 participants last post by  Early Iron Motorcycles
#1 ·
I see these every once in awhile. Are they solid struts or are they really shocks? I like how clean they look.
Where does one find these?
Thanks
#2 ·
Spitfire spring struts. I ran a set. There's a teeny bit of cushion... but I also weigh in at 275. They pretty much ride like shit, and because the ones I have seen are 10" from eye-to-eye, there's not a lot of clearance...
I've never seen the covered ones before. Google "spitfire struts" to find them. I have a nice chrome used set I'd part with if you can't find anything.
#6 ·
Compression spring only. There's no need to damp the rebound, really, because there's no actual pogo action; they're like friggin' valve springs.
#8 ·
That sounds right. You can get those die springs in an amazing range of physical sizes and weight ratings. They are usually pretty durable; I wonder if the breakage problem wasn't related to embrittlement from the chrome plating process?
Geo.
