'79 triumph - right hand shift???
12K views 27 replies 10 participants last post by  whittiger650
#1 ·
A buddy and myself are going to pickup a '79 T140 Triumph on Sunday. Nice original with no evidence that it was ever taken apart. New exhaust and seat, last driven two or three years ago. $1800, so it's a good deal. Owner says it was imported from Europe in the 80's to California. It has a right side shift on it, though. Does this sound right? The frame and engine numbers do match.
#9 ·
No, they were all left hand shift.
Not too much of a hassle to convert one to right hand shift though, using all factory parts.
Anybody ever talk to "that" dude who thinks he knows what he's talking about and tells you that Triumphs and BSA's had the clutch on the right and the throttle on the left :rolleyes:
#6 · (Edited)
actually it was the Japanese that lobbied the Congressional D.O.T. committee into believing after 50 years of riding those bikes that were right side shift are dangerous.
This was done mainly to kill the struggling British motorcycle industry and also put a major hurt in Harley Davidson because all Sportsters up until 1974 were also right side shift bikes.
flat trackers will tell you that right side shifting is "normal".
#8 · (Edited)
The conversion to left-hand was done to all market bikes. So any Triumph from anywhere will be left-hand shift from '76 - up.
Note that the Bandit prototypes were all left-hand shift.
The left-hand shift c*a*n be converted to right-hand, but it takes a LOT of parts to do properly. Some of which include:
Outer primary cover.
Inner and outer transmission covers.
Shifter and all associated parts (pawls, carrier, etc.)
All brake components, as there were NO rear disc with right hand shift. The addition of the rear disc coincided with the change to left-hand shift. The addition of the brake components will necessitate welding to the frame.
Note, too, all LHS are 5 speeds, and all are T140 750cc.
Correction: there were some short-stroke 650's in '81 and '82, not officially imported to the USA.
Cosmo
#12 ·
If the numbers match then there is something very wrong. I would guess a restamped motor. There are some other telltale signs to check if it is really a 79 or later motor:
There are 2 nuts and several allen head screws that hold the gearbox cover on. The upper nut should be an acorn. The lower nut on a 79 is a lester nut. You will probably have to crank the kickstarter to see it. A lester nut looks like this:
The primary breather hose runs up to the airbox.
The head should have parallel ports.
The points cover should be ribbed aluminum and not smooth chrome.
The bike should be negative ground and have Lucas Rita electronic ignition.
If any or all of these things are not there then I would guess an earlier engine has been fitted.
Scott
#14 ·
We got the '79 t140 home today. It appears that it was converted to a right side shift at some point. Other than that, it's all pretty original. The paint isn't the best and it will need a battery and the fuel system and brakes need attention.I don't think it will take to much to get it running. Ended up getting it for $1200 and it has a clean title. Over all I think I am pleased with it.
#21 ·
Well, that looks like a nice bike and the brake set-up was done very well it looks like.
It definitely looks to be a T140E.
For some reason, I was thinking you said it was a T140D Bonneville Special but just searched your posts and don't see any reference to that...how I got that I don't know !
But regardless, sweet bike and nice score :cool:
This post has been deleted
#22 ·
Where do you see those numbers on this bike? Those are 1970 numbers anyway and from what I can see of his numbers they don't match what you posted.
well dodgy looking number ya have there!!!! ND30770 changed to ND 30752 !!!!
I wouldnt let a cop see that........new case time I think....or take it back where it came from....
#23 ·
Ya, I'm not sure what Magnumpete means there?? Engine, frame, and title numbers are all good. And as of today, she's a runner. Didn't take to much, new battery, plugs and fresh gas and it started on the second kick. Happy, happy, happy. Needs several things yet before it's roadworthy though. Not that it matters a lot, but does anyone know what that left hand brake pedal might be from?
#24 ·
you,or someone posted a clear picture of an engine number but it has since been removed....in the picture the number had obviously been changed.......put the pic back up and it's plain as day......if it wasn't you who posted the picture with the numbers I'm sorry but it was here long enough for me to see and write my reply......
