STARTER BOLTS-loctite?
4.9K views 5 replies 6 participants last post by  lotus
use red on the starter mounting bolts to the outside of the inner primary and blue on the bolt that goes in the jack shaft and Dont over tighten .also if you use red on that one it could break when you have to pull it out. then that will be a nightmare.
