This opened my eyes when I was researching about cams.
It is not possible to add low end power - commonly referred to as torque - and top end power, commonly referred to as HP at the same time to a naturally aspirated engine by installing a different profile camshaft. The whole concept of torque/HP is a marketing concept. Power is power. You get top end power with RPM; you get low end power with displacement.
THe only way to get both at the same time on a conventional engine (no adjustable valve/cam timing, no adjustable intake volume) is to increase displacement and/or compression and make whatever changes required to keep the engine able to spin the same (or more) RPM. When Norton increased the 750 to 828, they boosted the low end because displacement increased but they could not increase the top end since the engine couldn't safely spin to 7000 anymore. They didn't want to (or couldn't) make the necessary component changes to allow this.
Although exhaust and intake tuning also affect the power curve, all the cam change can do is shift the power band within the bikes RPM range. It CAN inrease max power over stock AND it can increase the power anywhere in the range that you want, based on the profile. BUT it CAN"T add top and mid and bottom at the same time. If you add power to the top end, you will loose power at the bottom. Obviously, changing the cam may - depending on what you are trying to do - typically requires many other changes to produce the results you want without creating a hand grenade.
So it's best to determine what you want the engine to do and then determine what is necessary to accomplish that. It may turn out to be impossible. Also consider rideability - hot cams NEVER make vehicles easier to operate.
http://www.johnsoncams.com/jc_t_cams.html
Your choice but with a race cam you'll lose the ability to snap open the throttle in top gear at 80km/h to pass a car, meaning your once torquey brit bike will be like a jap bike to ride, no torque until it comes 'on cam', but they've got more than 4 gears to be changing, that's what the bloke above means by easy to operate.
T75 ( 2 x 750 inlet profiles) can be easily timed using 750 timing pinions, a few blokes I know dig the T75's but there's heaps out there who swear by what they've got as well, the sifton 390 sounds alright.
You'll have to change the crankcase breather too, here's a pic of mine, a BMW reed valve in a home made housing, first it filters through 2 SS pot scrubbers in the cavity.
