I'm wagering that there's probably not many out there, but does anyone have any pictures of decently and tastefully done FL swingarm bikes?
No, the bike is registered by the frame numbers (big bore engine with Delkron cases) so I had to use the original frame. He wanted the bike to sit as low as possible. I cut the frame under the seat and put in a stepped frame section out of a totaled kick start, swing arm frame. Then I dropped the lower shock mounts into the swing arm instead of having them on top of it. Used a little shorter shock too. I raked the frame 5 degrees and extended the front end 2" with extended bells on it. The bike is a little flashier than anything I'd ride, but he was happy with it.lilbill said:larryt, how did you lower the ass on that blue bike ? is that an aftermarket frame ?
Yeah, this stuff can be a lot of work and when you're finished not many people notice what's done. Kinda like what I'm working on today. I'm filling about 60 holes in the cowl of a 56 Ford pickup. When it's finished, all of the work will be invisible. LOLlilbill said:ah sooo.... that's pretty much what i'm doing to my shovel right now. i cut the frame under the seat last night and lowered it down (got the same oil bag you used) and today i'm fabbing in the spacer blocks. i had moved my lower shock mounts to under the swingarm with 12 1/2" fxdi shocks but the chain hit the starter drive box so i moved them back to the top but slid back an inch. i'm working on a bobbed fender now (started out as a stock 73 fx fender) which i plan to lower in the fender struts as far as possible and still maintain tire clearance. might even flip the struts upside down. man i tell ya, dropping the ass on a swingarm bike is a bitch.
the trick is to drop it while leaving the suspension functional...otherwise it might as well be a rigid.lilbill said:...dropping the ass on a swingarm bike is a bitch.
a rigid huh ? is the fender in stock relationship to the struts or did you move it around to fit the seat bottom ?Larry T said:The seat on the blue bike is a Mustang seat for a rigid.
One of my new favorites NICE BIKEheres mine
one with apes.
dont mind the lines in the last pic. was still working on the air ride.
