Yes another frame I.D....Please
1796 Views 12 Replies 8 Participants Last post by  rustbike
anyone give me the manufacture of this frame
my shovel im building has same thick box-ish motor mount like this pictured one
any info ???
thanks
1 - 13 of 13 Posts
Are there #'s across the front motor mount ? looks like an early jammer frame
thats my frame.
Early Paughco (North Hollywood) frame. i'm pretty sure.
the welds are alot thicker than the newer Paughco's as well.
Standard.
if you like pm me your email addy and i'll send you more photos of specific area's that may want to help identify yours.
looks like a early jammer, beefy cross over area
early Paughco's were like that too.
either way,i dig it. quality built.
Yes Paughco..
Difference between a Jammer and a Paughco is the billet chunk of steel rear motormount on the Paughco..
And the neck gussets (on the downtubes) go deeper down on a Paughco against a Jammer..
I posted the differences with pictures long time ago somewhere on here..
You should be able to look it up again..
THANKS GUYS
all your info always helps
thats my frame.
Standard.
[email protected]
thanks
Josh
here is the frame section from rear motor and front of trans
sorry for the cock-eyed pic
still look like early Paughco ???
any takers
Josh,
check your email.
sent you photos
Does one or both of you want to do me a favor? I talked to Jason at Paughco and he said he has no problem making me a North Hollywood style frame. He said the only real differences between them and the current frames are two things. They used to use 1" tubing and now they use 1 1/4". Also the back bone is raised to accommodate the evo. He also said that all of the old North Hollywood frames had they're logo stamped on the rear motor mount. He said they don't do that anymore because the die broke quite some time ago.
Anyway, He said he needs a measurement between the top of the rear motor mount and the bottom of the back bone right above said mount. If one or both of you could send me that measurement that would be awesome.
Thanks fellas.
-Chris
White Nightmare could you post that measurement when you get it? Thanks.
D&D i had the same 1 try and get the paint off the top motor mount its stamped d&d
1 - 13 of 13 Posts
