I'm completely re-wiring my 72 OIF 650 Tiger (because the previous owner decided to remove the harness) and before I risk frying my new Podtronics Regulator, I want to be sure I've got everything hooked up correctly.
I've looked at all the wiring diagrams posted (even the bad ones) and none can be perfect, so here's my question.
Points wires: B/W going to Neg. terminal on Left Coil and B/Y going to Neg. terminal on Right Coil (don't think it matters which coil)
Coils: Left Coil Pos. terminal to Right Coil Pos. terminal
Condensors: Neg. terminals of both Coils to their respective condensor and condensors to ground
Podtronics Rectifier: G/B & W/G stator wires to rectifier's yellow wires, red (+12v) to frame, black (-12v) to ignition switch (but which terminal? accessory?)
Battery: Positive Ground to frame, Neg. terminal to ignition switch (again, which terminal, accessory?)
As the bike was wired, the ignition switch was wired to the Left Coil's Pos Terminal.
Does all this sound correct?
