Is there a white wire from the module to the coil? It should go to the 12V side.
if you reversed the 2 wires to the coil or ign. And sent power to ityeah, it's white, i just couldnt color it that way in my shitty drawing. I did however momentarily have the wires to the coil reversed...could that have fried either the coil or the module?
You should run a kill switch but it won't have an effect on the workings if ya don't.thanks geezer, I'll try this tonight and report back. appreciate the help.
wait though, I don't have a kill switch...should I have accounted for that somehwere since I'm using stock ignition module? I've got basics only on it, like the diagram above, except I kept the voes...
