I've got a star hub I want to lace to a old D.I.D 185B 19 rim(40 hole shallow drop center).
Do any of you wheel builders foresee a problem mating the two together?
I'm new to wheel building so any help would be appreciated.
I called up Buchanans to order a set of stainless spokes/nipples, and found
I might be able to use a pre-packaged HD spoke set with a swap out of bigger dia. nipples to accommodate the rim. Then I got the "what did the rim come off of originally" question and I couldn't answer that one
, cause I don't know (swap meet special,hub cut out of spokes). I'm not sure why that matters (spoke length/nipple angle?). Anyway, I canceled my order to try and find out more info on the rim hub combo.
So if anyone knows what this rim would have been on originally, that would/could help me out as well and hopefully the combo will work together.
Thanks,
skinny
Heres a couple of pics for reference:
Thanks,
skinny
