1 - 8 of 8 Posts
Flyin' Dutchman said:
That thing looks wicked...
its a morgo
cool idea
way fuckin overkill
too much work to make them not blow seals and gaskets
i like their std type
is that yours?
Brian Douglas said:
its a morgo
is that yours?
No.. It's not mine.. I just found this pic and wanted to know what kind of pump it was...
I think I have a standard type morgo... I had to trim it down to fit my timing cover. The first timing cover I mounted cracked because it didn't clear the pump by a millimeter or so.
Can you give some more info and expand on this point some more?
YO tilly!
I was looking at these for my pre-unit. $$$$!!!!! Big bucks! Lots of flow, but I have heard some of the negatives too. I run that external spin-on filter and I've heard a couple times it will blow-by the filter if it's too much flow for the filter to handle. The other biggie I heard was you have to restrict the rocker box feeds a little too because of the extra flow. Really more flow than what the motor was designed to handle is what I walked away with after some research. I don't honestly know how much truth there is to the things I heard because everyone seems to have there own "expert" opinion on things, but that's my input anyway. They ARE wicked looking and a good design for an oil pump. Ultimately I ended up using a Morgo stock style plunger type that was just slightly oversized. Figured the slight more flow would be good since I'm running that spin-on external.
well, remember all the races that the triumph 650 won in the 60's?
all of them used stock pumps...
when was the last time you heard of the stock pump failing?
i dont buy the higher oil pressure=cooler running either
cheaper, easier, and more efficient to run a oil cooler
heres the listed modifications from morgo
http://www.morgo.co.uk/unitfit.html
heres one example http://www.britbike.com/ubb/noncgi/ultimatebb.php/ubb/get_topic/f/13/t/002378.html#000000
theres a shitload more of same
i do really like their 750 kit tho
1 - 8 of 8 Posts
