1 - 3 of 3 Posts
80" shovel/ 9.5:1 wiseco's/ 93 octane fuel
I just rebuilt my top end entirely and have begun to notice some detonation in 5th and 6th gear when I wick the throttle wide open..
The pistons I replaced were 9.5:1 wiseco's as well...
Checked my timing...I'am 32 degrees advanced (35-40 is the spec I believe)
so what give's? Should I just keep retarding my timing until the bike runs like a damn turtle but doesn't ping.....? I've got a set of heavier duty advance springs I might try out...anything look/sound abnormal here?
thanks in advance!
with fresh rings, even with the same pistons, you'll get higher compression because less gas escapes past the rings. why not just limit your advance, instead of retarding it more?
If your 5th and 6th gears are tall as hell wicking on the throttle is going to put a pretty big load on your engine. 9.5:1 is still relatively low compression in the grand scheme of things running 87 in an engine with a nominal compression ratio like that shouldn't even give you any troubles.. It might be the matter of a degree or two causing it to ping.. Does it do it in any other gear? Do you have your valves adjusted correctly?
1 - 3 of 3 Posts
