1 - 20 of 28 Posts
What solvent or cleaner do you use? Is there anything that can be disposed of easily that actually cleans parts?
We used some enzime stuff when I was in the Marine Corp that was easy to get rid of but that needed to be kept in a heated parts cleaner to ?stay alive? I don't remember so good!
+1 on Simple Green.My shop/garage is attached to my house, added the fact I have kids.It does work pretty well.
Not to rain on anybodys parade, but just fyi......Google EGBE, the main ingredient in simple green, and you might rethink that choice. Especially the part about "testicular damage" I'm using good old fashion 515 thinner aka "safety solvent"
I have a Graymills parts washer and it came with 30 gallons of Agitene. The Agitene works really well. I don't know about disposal. I have a friend who uses Kerosene in his washer. The Kerosene works okay, but you probably wouldn't want to use it if you're a smoker.
I use citrus cleaner from a bicycle shop. Works great and smells nice.
Cant beat the good old kerosine and a pair of gloves.tried a few other compounds but they do not cut the mustard in comparison
slightly used Varsol from the state hospital's motor pool. It still looks new, but they have all these reg's and stuff about use time, they cull it way early being state funded and all (tax dollars hard at work...). I get that shit for free, then take it back to them after its good and dirty, safety clean guy is none the wiser.
-A.
Diesel fuel. When it gets dirty i can burn it in the shop stove. Soak news papers in it to start the logs.
In the past I used stodard solvent, then moved to Safety Kleen. Recently I started using WD40. I am thrilled with the results I am getting. But like most I want to use what works and won't kill me in the long run. I also use Dawn dishwashing detergent with hot water and a stiff brush.
....at4% I dont think it can be called the main ingredient.However the chemical itself is not good & Simple Green shouldnt be labeled as a "green" solvent having EGBE in it at any percentage.Looking at the MSDS, used as directed doesnt appear to be the worst choice of cleaning slovents out there.But when I chose it I was looking for something safe....so thanks for that heads up.I will be looking for a safer alternative.
I use a 50/50 mix of acetone and hydrochloric acid. That's safe, right?
Just kidding :D -mineral spirits
The simple green max I use (not the industrial stuff like I said before) does not have EGBE in it according to the MSDS.
http://www.simplegreen.com/pdfs/MSDS_EN-CA_PS-Max.pdf
Looks like it's slightly different in the normal stuff now too.
http://www.simplegreen.com/pdfs/MSDS_EN-US_AllPurposeCleaner.pdf
Good heads up on avoiding stuff that has EGBE in it though...I'll just keep using what works and hasn't killed me:D
Nice one Dan...HEY YOU GUYS!!
http://en.wikipedia.org/wiki/Acetone_peroxide
1 - 20 of 28 Posts
