Yeah I know.....this is gonna be tough without being nearby to hear it.
My '72 TR6C is starting to make a weird noise and its getting progressively worse! It sounds like something is pinging off the exhaust at the top by the primary side pipe where it enters the head. Either its worse when sitting still, or I can't hear it over the engine noise above idle. Can't tell if its internal or something loose somewhere, but the noise doesn't always correspond to engine RPM.....leads me to believe something is vibrating somewhere. I've been all over that area outside the engine and all seems secure. So far I've checked primary chain tension and clutch adjuster locking nut and both are ok (clutch nut seems close to insp. plug, but neither is shiny indicating contact). Airplanes are loud so my ears aren't so great anymore. I sure could use some tips to locate the source of the noise!
Thanks!
Johnny
Thanks!
Johnny
