1 - 8 of 8 Posts
Discussion Starter #1
I have a VL frame and a DNA springer (i know not cool). The springer uses a 1" stem and the frame has 1 1/8" cups. How do i solve the problem without spending a lot of money???
thanks
Sleeve a set of regular BT 1" cups to fit the VL frame. It is dead easy!
Robbie
if you own a lathe its dirt cheap. or if you have access to one and know how to use it. otherwise, you better start working the corner lol
Cut the neck off of the frame and replace. Chop the frame while you're at it, those things are a dime a dozen. Don't forget to use plenty of pike nuts.
1 - 8 of 8 Posts
