1 - 3 of 3 Posts
So I went through the wiring thread in the tech achieve
http://www.jockeyjournal.com/forum/showthread.php?t=41493&showall=1
and looking at the stock wires/wire diagram and have came up with the following. I know this has been talked about a lot on here but just want to make sure I am not missing something. So if someone more wise then I could chime in and let me know if what I have will work or if I should change something.
Thanks
Ok Drake, i'll jump in. The hot off of the bat goes directly to the starter not the sol. 4 wires and one of them being the heavy wire going to the starter is going to be tough to get in there, 2 sugestions, 1- use a key switch that has a spring loaded start position (NAPA has a marine use one that I have used for years and works well), or 2- come off of the back side of the fuse between the bat and ing switch to power your relay.
1 - 3 of 3 Posts
