1 - 8 of 8 Posts
What bronze do you recommend for valve guides? We just made one out of 660 but was told that 630 or ampco 45 is the way to go. I cant find any ampco 45 for sale but online metals has the 630.
Also need to ask how your removing your valve seats. There's the machine out method and was told you could weld onto them, when the weld cools it will shrink out the guide enough to tap out w a drift.
Thanks,
Toby
Toby!
You didn't even tell us the marque of vintage of machine.
Or the application, such as competition or cruising.
If you are speaking of an H-D up to '84, for normal service, I would advise against any bronze guide.
Bronze has a habit of shrinking, as you described...
It is not a good thing if your timing changes, or you develop a vacuum leak, etc.
But the stuff given to me that was supposedly ideal even for flattys has C90500 on it. Still, it is safest to limit any bronze to intakes only.
....Cotten
66-68 Motobi/Benelli Barracuda 250cc OHV 4 stroke, italian light weight thumper, aluminum head/barrell/cases
Original guides are def bronze or brass alloy, cant tell the exact makeup but they are splintered bad on the CC side. After a little research I'd guess the stock guides are manganese bronze. I read an article about how the Europeans used a lot of it. It was a really cheap material and easy to work with. Didnt seem to last but it was cheap to fix. I'll post some pics of the carnage later.
I have used diesel Ford tractor valve guides as a template. If you are making your own, I assume you have the equipment to turn them down to shape and bore/ream them. I have a bunch of these cast iron guides I would be glad to ship a few off to you to work on.
Check out my thread: http://jockeyjournal.com/forum/showthread.php?t=93016 it details how I fixed an enlarged guide hole with the very guide I am talking about. Worked like a charm.
Original guides are def bronze or brass alloy, cant tell the exact makeup but they are splintered bad on the CC side. I'll post some pics of the carnage later.
DUDE! WHAT? lets get some pics of this thing!! sorry i cant help in the materials dept, but oh my god, please share your project!
welding a seat out is an geat way to get them out without maching,BUTyou betterknow what theyre made out of.. and how theyre constructed. cast or powderd, etc will come right out...beryilium and alloys will melt,explode, and do everything but come out and become a nightmare to machine. also beware of cast in seats..in a moment of stupidity i tried to weld out a set of panhead seats because there were no guides to center our seat cutter on.. 8 hrs later i wshed i was never born and found out the head is kind of cast around the seat...its twice as big as it looks encased in aluminum casting, i saved it but almost at a set of numbers matching early panheads. as for guides if its not an all out racer i would find a bronze automotiive guide and trim it down /hone/ream burnish it to fit..we do it all the time on old shit to save it...when all else fails a big block chevy guide is aalmost .750 o.d. and you can put a bronze liner in it to get the id right..
Sorry man, its completely dissasembled and in a crate, not much to show right now. I had it shipped to Texas from CALi. I really need to get organized and start a build post on it. It came with a race frame with custom trees and rear sets. Its gonna be the bidness once its together. I already have a 125 5 speed and liked it enough to find a 250. Here's the 125.
Discussion Starter · #8 ·
Thanks for the offer. I ended up ordering 1' of bronze alloy from onlinemetals.com. Were gonna work it out. My neighbor is a retired machinist and keeps himself busy helping punk kids like me. He got bored over the weekend and made a guide from 660 just to see whats involved. He's a saint. I took him the motor today and he's going to make a couple gear pullers so we can split the cases. The pinion and cam gears are helical and the teeth are easy to chip with a normal puller.
1 - 8 of 8 Posts
