Maybe you can find an installed height for the springs, then interpolate?
Use new valves.. oversize may gain some real estate
Yeah, it already had oversize valves when it got to me. The manual shows installed length to be 1 3/16 on the outer spring. Putting the lower spring seat in place, with the upper retainer and keepers installed, the shortest one measures about 1 1/4. I'd sure like to have an actual number that one can get away with on this. Even if I have to find another head, or replace the seats in this one, a number to work with would be a very good thing, if for no other reason than to tell if another head would be saveable by measuring the valves before starting to work on it.Maybe you can find an installed height for the springs, then interpolate?
Sinking them to allow more lift wouldn't really accomplish anything. Any extra lift would be negated by the shrouding from having them so deep.I wonder if the valves were sunk purposely to allow more lift?
Why would someone bury them that deep?
Not guides. Valve stem protrusion. Distance from the top of the head to the end of the stem. It has to be within a certain range in order for the valves to be setting in the correct position, and in order for the rocker arms to push them down instead of sideways and not interfere with the spring retainers. Valves that are sunk too far into the head are also shrouded around the perimeter and don't allow proper flow. Every brand I've ever worked on had a set spec for allowable valve stem protrusion, Triumph doesn't even provide it at all anywhere that anyone seems to be able to find.late to the party. 'protrusion', of the guide into the port? . Stan Shelton says only short if used for track racing and therefore stripped and rebuilt more often. Longer guide gives more support, a six degree taper and on the top of the guide put a chamfer there so oil isn't inclined to sit there and get sucked down guide, also look at 0.015" guide/ stem clearance, wish somebody had told my machinist that last one.
That is absolutely the goal of knowing the acceptable valve stem protrusion, specifically to get the contact points between stem and adjuster to meet properly. It's an easy thing to check and get right IF you have the numbers. I don't think just eyeballing it with the rocker box setting on the head is good enough, especially when dealing with things that have been knackered and bodged by countless others before. In order to get a really good view of it, one would have to cut apart the rocker box so that it could be checked from the side.Just checked, it states that at mid lift adjuster ideally should be in line with the valve with contact point central to valve.
Caps are perfectly acceptable as long as the valve stem has enough space above the keepers, some don't. In this case I'm using stock spec valves and returning the head to as close to new condition as possible.In consideration of after market valves where stem length can vary, it goes on to say, machine valve stem length down or too short, use valve caps.
Absolutely. With the 45 degree angle of the valves, a very minor difference in thickness can be fairly significant when it translates to rocker/stem relationship. Unfortunately, one cannot just put a thicker gasket in to compensate for taller valve stems. The valve angle moves the tip of the stem away from the axis of the rocker as much as it does up.Also on Triumph the rocker box gasket thickness will possibly change everything when replaced.
