Does any one know if there is a twist clutch available to fit an Evo Sportster trans? If so do I have to do any modifications to the trans?
I was looking for that as well. Never found anything. Magura is now making a hydraulic clutch kit for the Sportsters that's cool but...Bludshaker said:Does any one know if there is a twist clutch available to fit an Evo Sportster trans? If so do I have to do any modifications to the trans?
an idea - if you can source the rest (slave) of the system ..nunyadambusiness said:I was looking for that as well. Never found anything. Magura is now making a hydraulic clutch kit for the Sportsters that's cool but...
I'd also say you could do a straight mechanical twist clutch and just a bit of simple math would determine if the helix for a common internal throttle would work....... but I'm thinking it won't even be closeBludshaker said:Does any one know if there is a twist clutch available to fit an Evo Sportster trans? If so do I have to do any modifications to the trans?
check out exile cycles.Bludshaker said:Does any one know if there is a twist clutch available to fit an Evo Sportster trans? If so do I have to do any modifications to the trans?
