1 - 16 of 16 Posts
I recently picked up a set a 71 TR6R cases to replace my 71 T120R cases. Everything looks good on the TR6R cases except they dont have the drilled hole on the bottom for the trans camplate plunger. If the cases are not drilled how is the trans held in gear on the TR6R? Can I drill and tap the cases and use my T120R trans in the TR6R cases?
Also is there any other difference I should be aware of?
Thanks
TR6R on left and T120R on right .
CJ,in 71 triumph used a leaf spring in place of the plunger. The drilled case is either not a 71 or has been modified to use the plunger(drilled). The cases(TR6 and T120R) should be EXACTLY the same. They also used the same trans. Jack
According to the numbers stamped on the cases. They are both 71's the TR6R is a GE and the T120R is a CE. That being said the T120R was supposedly a race engine so who knows what they did.
Thanks for the info.
cj, the numbers are on the primary side case,the gearbox is on the timing side case. On the bottom of the motor, just in front of the gearbox,is a boss(motor mount),that has numbers stamped on it,they should match. If one side has been replaced, they won't. On your pic, I can't quite make them out,so let us know. Jack
Discussion Starter · #8 ·
All the numbers match on both cases.
Thanks for the link, Skajaquada
I snapped a couple pics when converting my '71 to plunger. The jig is easy to set up and works as it should.
Just need to clear the gearbox out..cover the bearings if you're worried about shavings.
Bolt up the jig
Then its just drill and tap the hole. lube recommended!
Plunger point should line up centered on the plate.
Might want to get an earlier camplate too, they're smaller than the OIFs. I've heard of either working though if ya get the spring tension right.
1 - 16 of 16 Posts
