1 - 4 of 4 Posts
Oil drain hole? That appears to me to be the passage that feeds oil(under pressure) to the ex. tappet block. It is missing the little sleeve. I have blocked it off when using aftermarket (hardened) cams,as it is not needed with them and helps with oil supply to the rods by not wasting it. Jack
1 - 4 of 4 Posts
