Try switching the spark plug leads (put the left one on the right cylinder and the right one on the left cylinder).
If it still won't start after switching the plug leads, try squirting some gas directly into the carburetors. If the engine starts and runs for a few seconds, you know the carbs are not working. If nothing happens, you know you have an ignition problem.
Your fuel lines are probably OK. What kind of carbs are on the engine? However, make sure you have gas flowing from the fuel lines when you turn on the fuel. If they are Amals, make sure fuel comes out the ticklers when you when you hold the tickler button down.
Make sure that the ignition timing is correct.
