1 - 13 of 13 Posts
On my next triumph build i want to run the head reversed,either by using a twin carbed 500 or a twined carbed 650 i could do the build with either.Do you guys have any advise about doing a reverse head job i know of a guy with a 650 that way and my motor man said he would help me set it up. Also could you guys post any pics of reverse headed bikes you have seen. I need ideas on what to do for exhaust and just to see what others look like i have only seen a couple and can't remember where. THANKS JEFF
I would imagine velocity stacks would be the worst thing to do, forever changing inlet flow with different speeds, good luck jetting that. Even more fun if it rains!
Never seen the reverse head deal with a 500, not sure why. It was very popular with the matchless crowd in the 60's, probably because it was an easy mod for them.
Lots of reasons I don't like the setup, but it's your bike :)
These from Willy J's site:
thinking it through, the hardest thing (other than trying to tune 2 carbs with velo stacks for highway!) would be the cams? or would it?
do you swap them? or do you just time each differently? its too early for me to think that one out withoutt being in front of my motor and turning the little wheels. ;)
if you swap them, youd need to rebush too as front and rear are different sizes (at least in mine)
i like it cuz its different, but hate the way it looks on twin or single carbed 650's....just looks funny, but i gots some other idears.........
-Rob
things to think about on a turned head:
on a pre-unit it is easy because you have magneto drive for the ignition. Wasted spark, both cylinders firing at once.
unit ignitions run off of the exhaust cam. Since you will be running the oposite way (exhaust cam in rear, intake in front) you will have timing issues to work out with your unit points.
turning a nine stuf head requires relocating the oil hole in the barrel to the rear where ther is no hole, use an early case or plug oil way.
way too much air coming in. less cooling effect on the exhaust. cool factor versus rideability
more to come as I finish up the one I am doing
Billdozer1811 said:
Probably a good reason why the factory never made one that way, huh?
-Bill
They had good reason for getting rid of rigid frames too... its like someone else said, cool factor vs. rideability.
1 - 13 of 13 Posts
