I bought a 65' Triumph not long ago and decided it was time to go through the motor. Found the primary adjuster drain plug was pretty much being held in by silicone. :eek: Most of the threads in the case were gone, so I had the hole welded up to try and drill and tap for a new plug. Now I wanna try and use a new stock plug, but im not totally sure of the size tap I would need for this.
Im thinking 3/8 BSP?
Can any of you guys confirm or deny this?
I believe a 1965 650 used 7/16" BSF threads at the primary tensioner. That's 18 tpi with a 55º thread angle, good luck finding a tap. The later bikes used unified threads, you could probably buy the later plug (part # 57-2259) and tap to fit. I think the later plug is 7/16" NC.
Eric
