Does anyone know the part number for the rocker studs on a 68 650 motor. The little ones with the nuts. Mine is missing one on each rocker box so I need to get a couple along with the nuts.... Thanks (I looked around but found a bunch of different part numbers not sure whats good for my boxes)
Next when you guys run dual carbs, do you prefer a dual throttle with two separate cables or a single throttle with a union joining near the carbs? Which do you find easier to adjust and deal with? As per your choice of throttle housing can you point me in a direction of a quality unit, whether it be dual or single and not cost an arm and a leg. Thanks
