Unit 650 - developed a pretty bad leak from the top-end recently. I've pulled the head, cleaned things up a bit, found a couple issues and now I'm looking for a little feedback before I replace what's needed and throw it back together.
I rebuilt the motor about 2 years ago (except for the head, which I shopped out) and have been beating it up as much as I can since. This leak kinda came out of nowhere, and even then it still ran well with no loss of power or compression that I could tell.
Here's what it looked like when I pulled it apart the other day:
While I was cleaning it up, I noticed a couple things, including the dimple on top of the right exhaust valve-stem. I'm guessing the adjustment was way too tight. I also noticed that the rocker spring on that side was completely collapsed, so that the rocker arm was floating freely on the shaft.
I don't see any cracks in the head and there was no sign of leaks around the push rod tube seals. It's a
66, so it's got the older style head/rocker box bolts that have to be torqued with the rocker boxes in place.
It almost looks like it was those inner bolts (that hold the back of the rocker boxes down) that may have been leaking, since I noticed some oil around those holes on the cylinder barrel and gasket, like oil leaked down from the head, through those bolt holes.
My plan was to run the head over some 800 grit on a piece of glass, replace the gasket, valve, and rocker arm spring... reassemble and see what happens.
My questions are:
#1, Am I missing anything?
#2, What would cause that spring to collapse in the first place? It looked fine when I did the initial rebuild.
#3, Do I need to think about replacing the valve guide? Didn't appear to be stuck.
#4, What can I do to prevent that same leak? Gasket-seal around the inner bolts? Replace with the newer style bolt/studs (i'm not convinced
that you can get a proper torque on the head with those older style bolts). I did use copper-coat when I built it the first time, and I followed the torque specs and pattern listed on the tri-cor rebuild sheet... I've read about annealing the copper gasket as well as some of the random home grown torquing rituals, but I feel like there is something else, specific to the older unit 650's that I'm missing.
Any tips or tricks are greatly appreciated!
Thanks
-BK
My questions are:
Thanks
-BK
