Cams=Megacycle510-60 ,a bloke here in Aussieland says these are the ones for big bore
Tuning your carb : start with getting the main jet correct ,a full throttle run(as the other posts suggest) for a 1/4 mile, up a very slight incline if you can as that makes the engine 'work' .Immediately kill the engine AND pull in the clutch at the same time.This is so you can see what the mixture was like at full throttle (Tan to light grey around the centre electode is what you are looking for) .White or blistered =lean,Dk brown /black=rich.then do idle(idle jet, but most modern concentrics have a fixed idle jet size) .Then do throttle cut away which controls 1/8-1/4 throttle then needle height 1/4 -3/4 throttle.I could go on but Seriously if you can wait a little i'll scan the Amal Hints and Tips booklet and post it on this forum,it says it all and is invaluable.
Drag pipes with a straight cut end are a pain on a street Bike(I speak from experience as it will run fine at a certain rpm but not at other)a slash cut is better as it reduces the strength of the pulse that effects exhaust tuning.
I wouldnt be too worried about the intake length on a single carb triumph but MAP did sell a bigger single carb manifold 32-34mm
It is worth reading the followng books ,as once you understand the theory behind performance mods,you are better able to know how to spend (and save your bucks)
Triumph tuning by Stan Shenton its an oldie but a goodie.
Tuning for speed by Phil Irving another oldie and it keeps being reprinted
The Big Twin high-Performance Guide by D.William Denish.yeah even though its focus is HD the theory applies to four stokes in general .I'd rate this as one of the best perfomance books on the market -bike or car.
Ok its late here and i'll post that carb stuff as soon as I can ,oh yeah the year of your cylinder head is cast inside the head in the area between the inlet valve guides.
cheers
cheers
