1 - 8 of 8 Posts
I can't seem to remove the drain plug from the trans, the small level bolt comes out no problem but the drain that it threads into is reefed in there. It would take a year to drain it all out of the level bolt. That damn plug is so thin you can only get half of you wrench on it, only if they had moved it over 2mm then I could use a socket. Is there any other way to get the fluid out without removing the cover? Thanks
1 - 8 of 8 Posts
