Hey guys:
I'm lowering the front end of my Trumpet build, and need some help.
The bike is a bit of a frankenbuild, so your expertise is needed.
Frame is a '58. Front end is from a 71-72 OIF. I measure the rake for that frame and the 71-72 front end at ~24 degrees.
With that setup, and a 21" rim, my tire is way too close to the frame, and I've got about 2" of suspension travel before dining at the shit buffet. Not ok. My solution is to use preunit trees to gain another 3 degrees (3 degrees, right?) of rake, and make up some new fork tubes (I need them already) to graft the 71-72 forks (34.5 mm) to the PU trees (33 mm).
With all the measuring + math I'm doing, I'm still unsure how much the fork tubes should be engaged into the fork lowers. I want to shorten them up so I actually have suspension travel, but I'm not sure how much I can shorten them.
