1 - 4 of 4 Posts
I just picked up a 66 tr6 bobber. Ithink it has suzuki forks but they are loose as hell. Anyone ever use this combo? if so what do i use for bearings? if not what is a good replacement disc brake front?
some jap forks are .5mm smaller than trumps...
So be a little carefull. if there super slack, find some forks that fit properly... jap or trumpet.
Bearings take your bearings down to your local bearing shop and they should be able to match them...
what size yokes are they (inner diam?)
also see:
http://www.jockeyjournal.com/forum/showthread.php?t=8204
if they're 34.5mm most late (80's) Jap and Trump foks should fit, i'm pretty sure the later xs650 has 34.5mm forks/yokes, they have disc/s and look okay. should be easy to modify the axle/spacers accordingly.
1 - 4 of 4 Posts
