1 - 9 of 9 Posts
The nut that holds the clutch on keeps coming loose. I put it on with a impact so I know it was tight but twice now it has come undone while riding. I don't mean the spring nuts, the big one under it. Am I missing a lock washer or something?
Time to take a $35 cab ride home to get my pick up truck. Fuck.
Later 650's, ('69-on?) had a locking type nut with no tab washer. It happened when they changed the mainshaft to SAE threads. But if you had it impact tight I bet something is worn or not spinning true and vibrating. Did you have the washer under the nut?
In addition to the good advice given above, with all these old bikes it's often a good idea to lap tapers with fine lapping compound before assembly. It's a good way to check whether the tapered surfaces are true or not. Obviously, if the taper is out of kilter, the hub will wobble around on there, etc.
Forget the impact gun,fine for your cars wheels but really not good for your poor old Triumph.Use a proper long torque wrench,some loctite if you must and try bluing the tapers to check for fit and correct with a swiss file.Lapping tapers is a waste of time.Check also your clutch rubbers are up to scratch
1 - 9 of 9 Posts
