It probably dies because of fuel isssues, but not because of vapor lock caused by a gasket or insulator. I have seen bikes run with gaskets, no gaskets, insulators, no insulators, gaska-cinch, yamabond, you name it.
Start with the fuel delivery. How fast is the fuel flow from the fuel tap? Is there a blocked gas cap vent? Has the cork or rubber in the tap swollen up and blocked fuel flow?
Try tickling it if it does not want to run when first cranked. if you can keep it going with the tickler the bowl is drying out or the pilot circuit is clogged. Check out the filters, they do get clogged.
It does not have to do with the gasket or insulator, unless they are leaking air, which would make it run lean.
