1 - 14 of 14 Posts
I BOUGHT A set of the push in exhaust manifolds for . They are listed for 750 for but are the same diameter for the head basically. They are not a direct fit. I heated the head and one slipped in without much resistance after claening both surfaces, the other no go. I sanded the collars a bit as good as i can by hand and one side is still large.
I was thinking of having one milled down to fit better it would be a very minimal amount , does this sound like a good way to go? I cleaned the exhaust ports with a hohning type sanding bit and they are clean and smooth . Should i just keep working the one thats large with emery clothe till it fits it wouldnt take much I guess maybe an hr. VS taking the head and spigot to a machine shop and having them work on it? I seems it should be added when heated for it to stay permanantly or could this cause problems? The outer parts of the spigots are kinda large too making it a pain to put the exhaust on they dont need to be so tight when you have exhaust clamps, so they need to be worked a bit too. the I could sit there and sand them by hand for a couple hrs and go that route. I have done it before making stuff fit, not every piece/pulley fits into a lathe, PITA. thanks in advance. More concerned about expansion...
Yea, skinner. I went ahead and sanded them down ok a belt sander and finished
with emory clothe. I did it a few time and heated and got them to seat with a couple light taps of a rubber mallet . I dont den kniw why I ask half the time cause I never wait for advice if i have an idea I'm comfy with. They are pretty snug , as good as the threaded ones. I imagine they will work as torque cones for the big pipes cause the opening from the exhaust is under 1.5 id now with 1.75 pipes. I have a couple sets of tt pipes I'm using thy are my fav pipes . So much better quality than the new stuff.
on an old 750 I had the ali' spigots/stub that pushed in had a knurled finish to hold them there.
eventually I had them Tig'd to the head because they would work loose.
Good fix while I had te bike, but if they ever got worn major head ache would be that they would have had to been machined out in order to replace.
6 of one, 1/2 dozen of t'other.
1 - 14 of 14 Posts
