Both those gears are stock Triumph. The gear on the right is early unit 650, around 1968 Triumph lengthened the gear to better support the bushing and give the seal a steel surface to ride on.
Eric
Eric
+1Both those gears are stock Triumph. The gear on the right is early unit 650, around 1968 Triumph lengthened the gear to better support the bushing and give the seal a steel surface to ride on.
Eric
I replaced my early transmission with a later one. I know the seal is a different size but can't remember if the access plate behind the clutch has a different sized opening as well. The trans that I got came with one and I just used it, cuz the guy I got it from made a point of letting me know that things were a little different. I can't remember checking to see if it was the same size or not. Maybe someone can clarify?Both those gears are stock Triumph. The gear on the right is early unit 650, around 1968 Triumph lengthened the gear to better support the bushing and give the seal a steel surface to ride on.
Eric
