Hi. I'm working on a '67 Triumph TR6 650 engine. For the connecting rod big end journal to bearing clearance the manual states a range of .0005" to .002" as the acceptable clearance range. I have new bearings installed. The crank and rods have been sitting in my cool-to-cold garage. With plastigage I'm getting a clearance measurement of .002" on both left and right. I've read that bringing the parts up to room temp can have a positive affect on clearances (making them tighter). It my not be noticeable but I'll measure again tomorrow night once the parts are warmer (I brought them inside this evening). What do you think about this .002" measurement and it being at the 'loosest' end of Triumph's range? I wonder if this range is the range within which a Triumph engine can be built, and if wear causing clearances larger than .002" is planned and acceptable?
What do you think?
What do you think?
