Tranny countershaft replacement
552 Views 1 Reply 2 Participants Last post by  Deleted member 9073
1950 el - 4 speed stock tranny.
The countershaft shows some minor wear where the needle bearings run.
I read somewhere that 1976 to ? countershaft could be used with the roller bearings for those years.
Are the countershaft bushing in later model the same as the 50's or
will they have to be replaced also?
I would be too lucky if someone made a replacement kit.
SJ
I'm running the late C/S on the 52...
Yes...The case bushings are diff. cause for the shaft is a few thousands smaller in size for the Torington needle bearings.
