1 - 11 of 11 Posts
anyone have recommendations on sealants. stuff ya like or dont like. ive always heard go easy on the sealant so you dont get a cloged up oil system. i kinda like loctite ultra black.
There is a rather recent issue of Classic Bike or Motorcycle Classics that delved into this matter rather deeply. Explored sealants to the extent, some I didn't even know existed. Two of them that seemed to consistently receive praise was Permatex RTV (the old stand-by), and YamaBond. There were some other excellent examples, but were harder to find.
If I can remember which month I'll let you know. If I can find it at home, I scan a copy of the article.
I'd like to see this article as well. Keep us posted! A scan would be awesome!
I've tried probably 20 or 30 sealers over the last ten years. I think I have finally settled on what works for me.
Loctite 518 - anaerobic (no potential for clogging oil passages) flange sealer that has major gap sealing capability. I use this the most. Primary covers, kicker covers, etc. If the sealing surfaces are nice, you don't even need to use a gasket. Easy enough to remove on disassembly
Loctite pipe sealer (don't know the number) - started using it instead of teflon tape. Is ready to take pressure immediately, requiring no curing time. Less likely to get in oil passages on disassembly than teflon tape.
Copper coat - a number of companies make copper-based gasket tack. It's usually an aerosol. If the application uses a gasket, and you don't want to eliminate the gasket or the assembly is frequently serviced, use this. Holds gasket in place, enhances sealing capability of paper gaskets, stays with the gasket, not the flange, on disassembly.
Threebond 1104 (or Yamabond) - this is the heavy artillery for applications that you just can't get to seal by any other means. An UNHOLY BITCH to remove later, particularly when used in conjunction with a gasket. Generally known to be the "standard" in case-half sealing.
Always make sure sealing surfaces are flat. If surfaces are marred and nicked, you may have to use more sealer, or one towards the "heavy" end. Clean the surfaces spotless with lacquer thinner or denatured alcohol first. This goes a long way towards no leaks.
jason
I agree w/ Jason on the 1104. I use it for crankcases joint faces (no gasket) but no where else as the shit is such a cocksucker to remove.
When I have to use it, been having good luck with the ultra gray Permatex. Matches case covers well. Use no more than a LIGHT smear on gaskets.
Haven't used the Locktite 518. Sounds like the ticket.
I was gonna give the Loctite line a try when I rebuild the one BSA. Haven't known anybody personally that had used it, so I was hoping for the best.
This is a helpful post that should probably get stuck in the tech archive for safekeeping.
jason
Hylomar. Developed 20 years ago by Rolls Royce and used on their aero engines. BMW and Jag has been using it for years and now Permatex handles it for us in the states. Also have used Yamabond and still use Form-A-Gasket #2 on the old mills.
1 - 11 of 11 Posts
