I prefer Rhys's suggested procedure because it opens up a much wider PDA (potential disaster array). Total mayhem is the best mayhem!> What could go wrong?
These are the things we've tried over the weekend...
after discussing the order in which to proceed, we decided to bench test the mag AGAIN, this time without any ground and without the power drill, just turning it by hand. It seemed to have good spark, but a little irregular maybe.
then we put it back on the bike and tried to get the spark to jump from the cable to the head or cylinder without the spark plug, like we just did on the bench. Won't do. We put the plugs on and got spark, but not the mightiest to be honest. Still, we got spark.
so then we decided to swap carbs first and see if we could kick start it with the freshly rebuilt Keihin Butterfly that used to be on the bike when it last ran. No success.
Then we pushed the bike outside and up a small bridge. We managed to get it running, but unfortunately the needle valve stuck open and the carb flooded, and since the magneto was retarded the bike spit flames and died.
at least it ran like a hundred meters under its own power. Lol. Looks cool though, and sounds awesome. I changed the needle valve and got the carb to work, but nevertheless, we did not really get it to run. Our suspicion is, that the spark is just too weak and gets blown out by the compression. Unfortunately we could not try and peg the bike with the SU, no time or breath was left.
we played with the gaps on the plugs, tried several different plugs, no effect.
So... Next step will be to put the oem ignition cone back on, temporarily wire a coil to the bike and see if it starts then. This is the most stubborn machine I have ever encountered...
Like i said, it's a mystery to me. I never had problems like this. Set the mag up and it would start somehow. That's why I love these, I always had more trouble with batteries and coils and faulty wiring and such...
I'll let you know when I learn more. Took the Flattie out for a spin today to deliver the cone and old ignition to the shop where the shovel sits at the moment... It just ran fine like always and I had a good time![]()
Pete, I fully agree, some of the shovels come to mind I've been around and them + a mag that's not in tune or timed makes your life a living hell. I don't think any of the bikes I've owned have had over 6:1 compression, probably less. So mag with timing and tune = no issues. It will be something minor and you'll be HAPPY haha.the speed of the kick is a hell of a lot with magnetos,
45's and stock low comp bikes like Knucks Pans & Shovels are piss easy to spin over fast enough, but anything with compression above about 8.5:1 compression & ya start having to really learn to kick with greater input,
I cant kick my shovel with my hips being fecked, & it having Wiseco 9.5:1 pistons & with the Leineweber cam, I'm just glad I got a Lectron carb as they alone help make starting easier whatever comp ya go for, having a real choke system & not just an 'enrichment device' that basically just temporeraly puts ya carb outa tune in a hope it gives a sort of choke effect, & most fixed & adjustable jet ventury (butterfly type carbs= BOAT ANCHORS !!!) are a pain if used with a magneto unless used with low comp pistons or electric starters,....
i uploaded the video of the last bench test to youtube. we spin the magneto over by hand, and it gaps 6mm with bright blue sparks.
Harley Magneto Bench Testing Part II
unfortunately, like i said, that changes when it is installed on the bike.
here's some pics from the day we push started it.
next step will be putting the old points ignition back on the engine and see if i can get it to start / find more things in the process.
in the meantime i will try and get a rare earth rotor (Morris P12) that fits my Burghardt unit. they are supposed to produce a stronger spark.
maybe that will help.
