The Burkhardt magneto cover kit has a major problem with the drive gear they supply, IT IS SHIT !! Typical V-Twin Mfg garbage,... they are far too oversized & MUST be replaced with one of Dave's at MORRIS MAGNETO, His are correct & fit, mine bound & sheard the pin on the drive gear on the Magneto base,
also, the BURKHARDT drive hasnt got a thrust washer between the gear and the outer tube , the thrust washer I salvaged from a 45 timer & I also used the 45 timer drive gear instead of the one that Tiawan Ted sends with the kit.
also one MAJOR thing to check is on the cross drilled oil galery, their casting is wrong & when drilled the hole breaks through into the cam chest & dumps all your oil there & the crank doesnt get any oil feed,
this is mine with the hole that I had to get welded up,...from what I have seen in some pics in adverts for the kit this hole seems to be factory welded but I guess mine being early production they didnt know or care if it was machined or cast correctly. I could have done serious damage had I run it for more than a few seconds, but as there was no oil pressure I took it apart to see why & found the hole, .....another reason why NOT to but any of the shit V_Twin & ted makes,
I must have spent a couple of days on the lathe & welder getting it fit to use, otherwise the castings prettu good, just dont use their gears, make sure theres no blow hole like on mine & fit a thrust washer between the mag drive & the drive shaft bush or the helical forces push the gear up into the bush & acts like a milling machine leaving brass swarf in the chamber the gears mate in the nose cone. .
if I had known at the time that Ted made them I wouldnt have bought it but it's sorted now & all works well
