1 - 4 of 4 Posts
easy ways to do it if you can weld and have some time.
make 2 1/8 x 1 1/4 bands that fit around the fork tubes with 1" tabs at the ends for a bolt. make sure you leave an 1/8 between the tabs .
drill 3/8 hole fof a bolt to tighten to the tubes. weld a nut on one side and add some gussets from the tabs to the round part.
figure out what angle and how far you want the bars to be.
tack weld in place and see how you like it
take apart and weld solid.
1 - 4 of 4 Posts
