21 - 40 of 43 Posts
Discussion Starter · #21 · (Edited)
Head all done ,
I was impressed by boiling carb with vinegar solution it was completely black (I gave it a scrub with paraffin first )
I’m trying to reuse everything that’s original on this bike.
Font Art Gas Wood Metal
Font Auto part Bicycle part Art Metal
Wood Gas Font Metal Rectangle
Gas Font Tool Metal Illustration
Wood Grey Road surface Flooring Asphalt
Discussion Starter · #24 ·
Ordered my carb manifolds wrong thread not 20tpi
So head is a 70 maybe 16tpi
Set up pushrod tubes with cup not happening
It’s a shit show
Discussion Starter · #26 ·
The pushrod tubes are now too long with the bottom cups
But now looking at the tubes closer and setting it all up with Orings looks like it will work without the cups
(I set up and compressed with a g cramp)
Discussion Starter · #28 ·
Yea to drain oil
But for sure leak at the bottom but not with magic Hondabond
Discussion Starter · #30 ·
Back on it.
Wood Outdoor furniture Gas Art Automotive wheel system
Packing materials Material property Rectangle Handwriting Plastic wrap
I remember doing Cush drive rubbers years ago what a cunt of a job, (hadn’t done since as I ran BNR belt drives)
Get the cases back tomorrow camshaft bushes reamed and crank and rotating bits all balanced
Hot dang! That's an excellent rubber installer (in German: Gummikompressor). In my sharply limited experience, Triumph cushes are the worst job to replace.
Excellent, definitely, but with all due respect your basement tech also reminds me of this guy's work:
If you're unfamiliar with Rube Goldberg, and have x hours of free time, google him.
Thanks for the Show & Tell.
Discussion Starter · #33 ·
First I cleaned with paraffin .
Then put in a small saucepan 1 carb dismantled poured in half a litre of vinegar added water until it covered all the parts then boiled untill I thought they looked clean 2 hours maybe ,it stinks and periodically I wiped the scum off the top with a paper towel . I assembled and then brushed with a soft wire brush.
2 carbs on the left I did ,other 2 came to me pretty clean
Font Gas Metal Cylinder Auto part
Discussion Starter · #34 ·
So got Vidal Sassoon on the job.
Bearings dropped straight in and closed her up.
gearbox tomorrow but have to be at pub at 12 for a wake.
Tableware Wood Table Gas Auto part
Automotive tire Motor vehicle Automotive design Engineering Gas
Motor vehicle Engineering Machine Auto part Metal
Automotive tire Motor vehicle Crankset Engineering Rim
Wood Gas Machine Engineering Metal
Font Engineering Gas Auto part Machine
  • Like
Reactions: HayMike
Discussion Starter · #35 ·
2 steps fwd 1 step back ,
Put the crankshaft pinion on and forgot the washer made a puller but kept shearing the heads of the bolts, proper extractor arrives tomorrow.
got generator studs with wrong threads and gearbox drain plug(lBSF on cases)
Wood Floor Flooring Font Road surface
Automotive tire Gas Machine Auto part Motor vehicle
Household hardware Gas Auto part Nickel Nut
Automotive tire Wheel Motor vehicle Tread Tire
Assembled gearbox pushed in selector fork shaft And it’s for later bike (no stepped end)
Hopefully find a spanner for sprocket but today
Or weld a bar onto a socket 41mm (1-1/58)
  • Like
Reactions: tzienlee
I very much like the home made puller & the use of a hose clip to stop it from pulling off the gear your pulling, I have tried a home made puller like that myself but gave up as it kept jumping off,... I never got the thought of holding it on with a hose clip but now I see it being done it's bloody obvious & will try it next time I need something pulled like that,..... great bit of improvisation fella,... in my 'tips' book now,.... thanks
Discussion Starter · #37 ·
Your gonna love my spanner then ,was sloppy so I taped two bits of thin steel inside
Automotive tire Wood Font Automotive exterior Bumper
  • Like
Reactions: tzienlee
Discussion Starter · #39 ·
gudgeon pin is a little bit tight a hair.(a ginger girls pube I think is the terminology)
Motor vehicle Automotive design Engineering Gas Machine
Bicycle tire Gas Engineering Bicycle part Machine
Made myself a reamer
Discussion Starter · #40 ·
Automotive tire Hood Motor vehicle Automotive design Bumper
Gas Electrical wiring Motor vehicle Engineering Auto part
Automotive tire Hood Motor vehicle Crankset Bicycle tire
Liquid Cosmetics Gas Camera accessory Cylinder
Automotive tire Tool Hand tool Metalworking hand tool Engineering
Font Material property Gas Food Circle
Got my extractor top tip grease it all before you use as turns in to a galled up mess .
Cylinder on(it’s new)I was looking at it and thought I’d drive out tappet guide blocks to see if was oring there on exhaust
Got 2 inlets(no drilled oilway)and there preunit
Another 50 quid later got 2 correct ones.(I could have left and drilled maybe?)
Exhaust has direct oil feed but not inlet I presume it’s because it’s hotter ?
21 - 40 of 43 Posts
