1 - 11 of 11 Posts
So the T100C has a single carb. Is that correct? I picked up a T100C motor and the head which came along with the motor has duel carbs like a T100R. Will it fit? What happens next? From the reading I've encountered, it seems the fitment between the T100R and T100C is external, like high or low pipes. Is there more than esthetics between them?
The head will fit. Not much more than esthetics between them. Nice bikes.
Relax, you're over thinking this....the answer is yes the T100C will work just fine with the dual carbs and head...if that's what you have, just use it and don't look back.
I read your post as you wanted to keep it a single carb. Yes, if you have the manifolds (1 each) for the two AMAL's you have and you want to run two carbs then you're good to go.
I'm curious. A single manifold will make it easier, but is it necessary? I'm not understanding something here. Will the T100C not accept duel Amals?
If you are going to run a single carb on a T100R bottom end or vice versa you will need to make sure the camshaft timing is set for that particular set up.
If this old brain remebers right, the T100R cam timing is set up to the dash mark on the cam gear and the T100C is set to the dot mark.
1 - 11 of 11 Posts
