Suspect TR6 frame & Hardtail. Run or Not
1792 Views 10 Replies 6 Participants Last post by  Drew71
10
So i started stripping the frame right back and getting all the bog off it and have found a few hidden dents ect, so took some photos of the frame and hard tail to get some advice on whether to run or not. This bike will not be a daily rider, but still not sure. was als looking at getting it all re-welded.
the dents are on the front down tubes. looks like it was ridden into a gutter. there not cracked but dents.
The bike is going to be a fairly ruff bike, so cosmetically i dont care, but i dont want it snapping on me either.
Also, hows that hard tail look to everyone?
1 - 11 of 11 Posts
the engine is a structural bridge across those dents, I wouldn't worry too much about it.
Thanks Tony! thats what i wanted to hear. hows that hard tail look to you? Im going to get a Bird loop tail eventually but going to just run this for now.
Also, Im getting the frame blasted this week, just wondering on the baring housing on the neck and if it should be covered/protected or is it all good?
the hard tail is kinda homely and rough,
but some of the best women I've ever ridden were also.
I used 2 lg. dia. fender washers with a length of allthread to protect inside the neck, I think I also used it when I powdered coated it.
the bearing races should never be powder coated, any good powder coating company should know better and mask them off.
Your right Tony, I also had the powder coat company sand blast the frame,and wanted more protection for the races during the sand blasting.Just being over protective I guess.
Turns out a Budweiser can end fills that perfectly.
hahaha, liking the Bud solution!
The downtubes were damaged by a set of highway pegs in the distant past. The rest looks fine and all looks like a very useable piece of kit.
Build it and run it as is!!
Cosmo
Pics 3 & 4, has someone welded over the top of the factory brass braze welds ?
1 - 11 of 11 Posts
