My 67 TR6C starts usually 2,3 kick. However after I add gas it's a mother to start. More like 30,40. Same routine, open petcock, tickler, gas kick etc. any clues?
Cheers.
When it's hot, try bringing it up on compression, ignition on, kick it. See if that works. Alternatively try wide open throttle. Probably doesn't need the tickler when it's hot and full of fuel. I know mine didn't.
Try this ..... Ignition OFF, tickle, Open throttle, kick, ignition ON, kick. Prime the cylinder with a little fuel. Thats how mine starts first kick. (Technically second kick i guess)
It's also possible that the float level is too high or the needle/seats aren't sealing too well and that the added fuel pressure (there's a actually a word for this, I think) is causing some overflow/excessive richness.
One assumes the engine would be hot because usually one rides to a gas station, but he could of course fill the tank from a can at home.
For some reason, my mind went the other direction. Excessive rich mixture will surely be a problem cold, but in a hot combustion chamber (Assuming it is warmed up of course) is less of a problem in my mind. Seems like lean is the issue to me. I wonder what the temp is when it IS running. Hmm. Ahh the glorious job of chasing gremlins. We all say we hate it, but yet we stay and endure the torture.
i'm seeing that if the problem is after filling up the motor is hot because the bike was ridden to the pump.
as above i wouldn't prime/ tickle the carbs if i'd only stopped for 5 mins, so maybe flooded.
if it's got points Glider's condenser idea could be a good one.
mebe carb's need tweeking, if running a little rich from cold no problem it's justlike giving some choke. But when hot that extra fuel is going to foul the plugs.
Yes it's when it's hot, as I ride it to the gas station. It runs rich, as before it used to die on me at the lights, so I tweaked the carb to get the revs up a bit at idle.
I think 59 might have it. My plugs always look dry & darkish, coked I guess because of running it too rich....
Double check the gas cap vent, loosen the cap before starting and see if it makes a difference. Also, do you have a thick gasket between the carb and manifold? Maybe the fuel is boiling from the heat transfer?
This sounds like the type of problem I'd run in to...........good luck!
Johnny
Have someone watch pipes when it does finally fire up, shot of black smoke your tracking a to rich gremlin. Could also pay to take out plug and see how strong your spark is when kicked. Ignition gremlins are a bitch.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Jockey Journal Forum
