the bt front end is 1" and the WL frame is 7/8" that won't fit
the rockers on the outside are WLC and the rockers on the inside are WLA
the WLC has the same type of front drum as the BT models (bolted on to the starhub) ,where the WLA is the fixed drum/hub wich is laced in the wheel
i'm sure you can trade the BT front end with some one for a WL type front end
the spacers can be made and there's no problem there
you will need the big front axle of the BT or WLC modelsfor the rockers
make sure you have the org. one before you make those spacers !!!
