1 - 9 of 9 Posts
TI_Tuesday
alrighty guys, i was told for more speed either go up in teeth on the front sprocket or less teeth on the rear. found a place that sells the front one for my bike but, it's only 1 tooth more. will that one tooth make any difference?
how about some science to go with that?
divide the number of teeth on the rear sprocket by the number of teeth on the front sprocket, this will give you a number, your final drive ratio like a car.
eg. 51 tooth rear / 21 tooth front = 2.428 drive ratio
now you change the rear to a 48 (i did this for el diablo)
48 tooth rear / 21 tooth front = 2.285 drive ratio
now to scale speed or rpm's, (since everything else: tire size, transmission, primary drive have stayed constant) you just divide these numbers.
old speed * old ratio / new ratio = new speed
top speed was 110 mph, so 110 mph * (2.428/2.285) = 117 mph at the same rpm.
make sense?
brandon
TI_Tuesday
Discussion Starter · #9 ·
dude that rocks. thanks. i have a feeling we may be seeing ya.
stolenmojo said:
cool, you guys keep me posted on your smokeout trip. i live 30 minutes away from the epicenter and will offer any and all JJ's my garage and tools for fixes and whatnot.
brandon
1 - 9 of 9 Posts
