Yeah but the Ones H-D uses Are Different, Using Heimi Joints will work, but only you will find out, the loads are different for the split wishbones on Hot rods.
Just for comparison, The OG Hardened Steel H-D bushings pree 48 with proper maintenance, would last about 30,000 miles, the Bronze bushings most aftermarket Springers use only last about 15,000 miles with proper maintenance, which you Know they don't get!
The Post 88 to current H-D teflon reinforced Kevlar Bearings Last 35,000 miles, so that is only five thousand miles more than the Pree 48 springers!!
And at Over $600 in parts to rebuild........
