1 - 3 of 3 Posts
any one with a early sporty running a front engine/oil filter mount .i took mine off it to powder coat thee framethen put it back on .it goes back on nice but the filter seems to be sitting a little croked facing the ground a few degrees .heres my question do you think it might the shimming for the engine.frame..im running the right monut a flat washer then a barrel shim then frame left mount then nut .same on top as bottom .does this sound right or m i missing a shim/washer somewhere .its a 68 sporty.thanks kyle
You may have better luck if you bolt the front mounts tight to the engine cases and then fit shims (washers) between the mounts and the frame tubes.
1 - 3 of 3 Posts
