1 - 8 of 8 Posts
I was looking for a belt drive setup for enclosed evo BT primary and found this deal on Jireh and was wondering as I have never run a belt drive setup before what would be need to make this work or a whole kit.
BELT DRIVE KIT U.S.A. Made 1-1/2" 8mm Belt Drives Ltd Use replacement belt part No. 58-139.
Electric start, closed primary, sprocket shaft nut & washer.
http://www.parts123.com/parts123/yb...~S3CG16C4Y474191711632a~Z5Z5Z5~Z5Z5Z50000123a#
Cluch hub,cluch plate's', steel plate's, presure plate and springs,spring retainer and adjusting nut's for the retainer. Also a cluch hub nut and lock washer and key for the main shaft. I am guessing this is going to be in a inclosed primary with elc. start. If your running a 4 speed primary & trans.
1 - 8 of 8 Posts
