1 - 6 of 6 Posts
Against all better judgement, I'm building an oil tank for my Triumph. Tony the Torch has mentioned a few times that oil tanks without froth tubes are no bueno, so I'm trying to get more info on what a good froth tube should contain. I believe I've read that they have stacked, perforated discs, but that's all I (think) I know. How many discs? How many perforations, and of what size? Any other information would be much appreciated. A picture would be especially helpful if anyone has one available.
The froth tube/tower/breather is hollow- nothing in it. The oil tank has about a 1/4" hole drilled in it where the breather is centered over it. No screen or filter. That's going off memory from a damaged pre-unit oil tank with a breather that was hanging off of it, so no pics.
Keep in mind, that breather/froth tower thingie was designed to route to the back of the inner primary cover (something you hardly ever see) so some residual oil is normal.
not really Pete, I have cut them open before and there is 2 disks spaced apart with the holes at opposite sides and on units it was vented out into space and all over the rear fender, your pants etc.
we cut it off of a cub tank and had to shorten it up a bit so we cut it just above the disk and there was another disk above that.
If you need a tower just hack one off of a cub tank, nobody cares about those..
1 - 6 of 6 Posts
